Access list help
Sep 30th, 2008
gues if i want to block two network
192.168.1.0/24 and 192.168.3.0/24
what will b ethe access list for that keeping in mind that i want to get the job done in one line (access-list staement) and can someone please tell me how you did that....thanks
Overall Rating: 5 (1 ratings)
Gerald Vogt Tue, 09/30/2008 - 21:21
  • Bronze, 100 points or more
access-list 1 deny 192.168.1.0 0.0.2.255
Giuseppe Larosa Wed, 10/01/2008 - 01:06
  • Hall of Fame,
    Founding Member
Hello Khan,
you need to think at the binary of the base subnet ip address
192.168.1.0/24
192.168.3.0/24
and look for waht they have in common:
they have in common the first two bytes and the 1 bit set in the least meaning bit of the third byte
so
192.168.1.0
the wildcard mask in ACL can contain multiple transitions 0 to 1 and 1 to 0.
0.0.2.255
the third byte is in binary:
00000010 : first 6 bits are 0 must match the last bit must be 1 must match the bit that makes the difference between 1 and 3 can be set to any value
so it is:
access-list 12 deny 192.168.1.0 0.0.2.255
notice that
access-list 12 deny 192.168.1.0 0.0.3.255
is wrong because is matching
192.168.0.0/24
192.168.1.0/24
192.168.2.0/24
192.168.3.0/24
that is not the same
Hope to help
Giuseppe
