PCAP Capture doesn't work
Answered Question
Sep 30th, 2008
Yesterday I did a capture on my ASA 8.0(3)12. I can view the internal capture via https://ASA-IP/admin/capture/CapName and https://ASA-IP/capture/CapName.
But if I try to download the PCAP file I get the download dialog and an error "pcap from ASA-IP could not be downloaded". I have packets in my capture so there should be a PCAP file.
Any hints?
Stephan
Correct Answer by scandan about 8 years 4 months ago
Hello stephan,
In order to download .pcap file you can use both CLI and Web Browser.
From CLI just copy the *.pcap file to a TFTP server
ASA#copy /pcap capture:cap_name tftp://tftp_ip_add
From web browser just add "/pcap" comment end of the "https://ip_add/capture/test/pcap" url.
I hope it will work fine.
Serhat
Overall Rating: 4 (1 ratings)
Correct Answer
scandan Tue, 10/07/2008 - 04:41
Hello stephan,
Serhat
stephan.ochs Tue, 10/07/2008 - 05:31
Hello Serhat
Thanks for your hint.
It seems to be a problem with my browser.
I still can't open /pcap via https.
But I can copy the capture file to tftp server and view it with WireShark.
Stephan
