Backup failing during upgrade from LMS 3.0.1 to 3.1
Oct 1st, 2008
I am trying to upgrade LMS 3.0.1 to LMS 3.1 as a fix for numerous bugs we have discovered. During the upgrade process it requires I take a backup however this keeps failing and I cant skip this process.
I have checked the backup log and the Error is:
Adaptive Server Anywhere command File Hiding Utility version 9.0.2.3402
Starting database engine dfmFhEng
Error(951): fatal error: database engine 'dfmFhEng' could not be started on database 'dfmFhDb' in Bulk mode..
backup Failed: 2008/09/30 12:21:12
Any help appreciated....)
Joe Clarke Wed, 10/01/2008 - 08:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
With Daemon Manager shutdown, please post the list of contents under NMSROOT/databases/dfmFh.
kviola1 Wed, 10/01/2008 - 11:33
Joe - I got the same thing doing re-install over LMS 3.1 on Windows 2003. Contents of the directory are: folder - orig, file: dfmFh.db
error rec'd:
No errors reported
Starting database engine dfmInvEng
[Wed Oct 1 14:55:40 2008] ERROR(969): Fatal error: Database engine 'dfmInvEng' could not be started on database 'dfmInvDb' in Bulk mode..
[Wed Oct 1 14:55:40 2008] Backup failed: 2008/10/01 14:55:40
Joe Clarke Wed, 10/01/2008 - 11:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You're not getting the same error. Your error is about the DFM INV database. Please start a new thread for your issue.
