CAT: auth in clustered config
kazinvestbank
Dear All,
have an issue here.
have a cluster of 3550 and 3560 catalysts running 12.2(44)se2 ios.
configured aaa and now can't access members with "Authorization failed" message.
from debugging realised that no username sent to connecting member switch, just blank.
have same config working well on another site with 12.2(42)
already smashed my head, please help.
aghaznavi
Level 5
Level 5
Authorization failed service. Looks like an authentication problem, but is an authorization failure.
Suggested Diagnostic Steps
To review AAA configuration, enter:
#show running-config
If aaa authorization exec command specifies method other than local, user fails shell access.
For example, aaa authorization exec default tacacs+ results in local user failing authorization.
For further information click this link.
http://www.cisco.com/en/US/docs/ios/internetwrk_solutions_guides/splob/guides/dial/aaasub/C262C6.html#wp1049952
thanks for your response
evr is ok with aaa. now I have to do 'exec default local none' instead of just local.
the problem is that when I do rcommand <#> from commander switch where is no username sent to the member I connecting.
I think this is an issue with installed IOS, so I plan to upgrade all to 12.2(46) later and see what will change.
here is some examples:
config
aaa authentication login default local group tac_admin group rad_admin
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication dot1x default group rad_eap
aaa authorization exec default local none
aaa accounting network acct_methods start-stop group rad_acct
and debug
000273: 5d12h: CLUSTER_MEMBER_6: AAA/BIND(00000080): Bind i/f
000274: 5d12h: CLUSTER_MEMBER_6: AAA: parse name=tty6 idb type=-1 tty=-1
000275: 5d12h: CLUSTER_MEMBER_6: AAA: name=tty6 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=6 channel=0
000276: 5d12h: CLUSTER_MEMBER_6: AAA/MEMORY: create_user (0x2A7A368) user='' ruser='NULL' ds0=0 port='tty6' rem_addr='10.131.167.128' authen_type=ASCII service=LOGIN priv=15 initial_task_id='0', vrf= (id=0)
000277: 5d12h: CLUSTER_MEMBER_6: AAA/AUTHOR (0x80): Pick method list 'default'
000278: 5d12h: CLUSTER_MEMBER_6: AAA SRV(00000080): process author req
000279: 5d12h: CLUSTER_MEMBER_6: AAA SRV(00000080): Author method=LOCAL
000280: 5d12h: CLUSTER_MEMBER_6: AAA SRV(00000080): protocol reply FAIL for Authorization
000281: 5d12h: CLUSTER_MEMBER_6: AAA SRV(00000080): Author method=NONE - PASS
000282: 5d12h: CLUSTER_MEMBER_6: AAA SRV(00000080): Return Authorization status=PASS
000283: 5d12h: CLUSTER_MEMBER_6: AAA/AUTHOR/EXEC(00000080): processing AV cmd=
000284: 5d12h: CLUSTER_MEMBER_6: AAA/AUTHOR/EXEC(00000080): Authorization successful
regards
