Jon Marshall Wed, 10/01/2008 - 04:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
It is static because the translation is not dynamically created when traffic goes through the firewall. This a permanent translation that you want all the time.
The purpose is because of an oddity with the pix/asa device. To allow traffic from a lower to a higher security level interface you need to
i) allow it in an access-list
ii) have a NAT statement for it
On most other firewalls you only NAT if you want to represent one address as another address. On pix/asa even if you don't want to change the address because of ii) you must have a nat statement and that is why you have it. It is almost a way of saying to the pix/asa i don't want to NAT for 172.16.32.0.
As i say it is an oddity of the pix/asa firewalls.
Jon
cisco24x7 Wed, 10/01/2008 - 07:00
  • Silver, 250 points or more
you either use static (i,o) same-ip same-ip
or nat(inside) 0 access-list with Pix version
6.3(x).
With version 7.x, you do not have to do this
if you have "no nat-control". That will
allow traffic from high to low.
HOWEVER, AS SOON AS YOU HAVE nat (inside) 1 x x
and global (outside) 1 interface, "NO NAT-CONTROL" WILL BECOME USELESS FOR
INTERFACE "INSIDE"
