VPN Client VPN3000 and Linux SMP
Oct 1st, 2008
i have a question about VPN Client for Linux.Is there any Client that works with a VPN3000 and multiprocessor ?
I found only this Message:
The VPN Client does not support SMP (multiprocessor) or 64-bit processor kernels.
Overall Rating: 4 (1 ratings)
hadbou Tue, 10/07/2008 - 06:31
  • Bronze, 100 points or more
The vpn client for linux requires RedHat Version 6.2 or later Linux (Intel), or compatible libraries with glibc Version 2.1.1-6 or later, using kernel Versions 2.2.12 or later.The vpn client will work with Cisco VPN 3000 Series Concentrator, Version 3.0 and later but it does not support SMP (multiprocessor) or 64-bit processor kernels.You may try using Anyconnect vpn client.
ksimsimon Tue, 10/07/2008 - 06:45
thanks for your help.
we have tested with the clientversion 4.8 and have it compiled with a multiprocessorkernel and now it works.
regards
Klaus
