intra-cluster communicatoin is broken after changing IP address of CCM6.1
Oct 1st, 2008
I follow the procedure to change IP address in CallManager Cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_2/ipchange/ipchg612.pdf
After I changed it, I run the command "utils diagnose module validate_network" and get the following error:
Error, intra-cluster communication is broken, unable to connect to [X.X.X.X]
How can I fix this problem? thanks!
1 vote
Marwan ALshawi Wed, 10/01/2008 - 04:25
i would suggest u to delet the ICT u have and rebuilt it again after u changed the IPs
rayon.man Wed, 10/01/2008 - 04:33
intra-cluster communication is broken. Not Inter-cluster
Anyone have idea to fix it?
smoran69 Wed, 01/28/2009 - 17:19
Did you ever resolve this issue? I'm having the same problem.
Sean
nelsonjuarez Wed, 01/14/2015 - 13:42
i have the same problem , but in cisco mediasense 8.5.4
