Cisco ACE Module: Admin Context
Answered Question
Oct 1st, 2008
If the design is that all the client/server vlans, vips etc are defined in a single context without need for virtualization, should the admin context by used for all the load balancing configurations.
100% of the resources should be allocated to the admin context.
Regards.
Correct Answer by Gilles Dufour about 8 years 4 months ago
Yes, if you don't need virtualization, you can use the admin context for loadbalancing and assign all the resources to that context.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Wed, 10/01/2008 - 05:02
Gilles.
