Can't view correctly CAR page
telecodi
Hi everybody
I have installed Callmanager 4.3 and now I'm fighting with CDR Reports. Follwing intrunctions on manual I have set up on CCM machine the CAR plug-in, then I access the CAR page but I can't see any of the tool bars with the menus.
I thought it was a Java plugin version problem or a IE version problem but none of this. I have tried from a IE v7 and a v6; I have also update the original Java plugin from v1.5 to version 6 but the result is always the same (see attached picture).
Any help would be appreciated
Dani
Dani,
This is possibly a problem with the installation then? You could try uninstalling the app via add/remove programs and re-installing again from the installation CD's (or try the downloaded plugin again)...might be worth a go?
Re-boot the server again after the install.
5 Replies 5
tim.giles
Level 4
Level 4
I'm not sure this is an IE or Java problem.
Have you tried re-starting the service in CallManager (CAR web service) or re-starting IIS?
Alternatively, you could be hitting this bug:
CSCsh45385
What version of CallManager are you on?
Please rate useful posts..
Hi Tim
I have restarted not only the services, I have restarted also the whole machine but no results.
The CCM version is 4.3 and the CAR installed, the found on services/plugins.
I have had a read on bug CSCsh45385 but it doesn't seem to be my problem
Dani
Dani,
Hi Tim
I have uninstalled and installed CAR again nd now it works. The difference is that this time I have done on the local console, not via Terminal Server. That was the trick
Thank you very much for your interest
Dani
Dani,
5*, glad to hear it's working and the re-install did the trick...
Tim
