aironet 1130ag
Oct 1st, 2008
I am trying to configure the aironet 1130ag AP. But I cannot enter the configure mode when I login the AP via console port. And how can I set up the mode of AP from lwapp to autonomous mode?
The info of "show version" is as following:
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
Activo uptime is 2 minutes
System image file is "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"
cisco AIR-LAP1131AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of
memory.
Processor board ID FOC12296DTC
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:21:D8:37:40:8E
Part Number : 73-8962-14
PCA Assembly Number : 800-24818-13
PCA Revision Number : A0
PCB Serial Number : FOC12296DTC
Top Assembly Part Number : 800-29144-03
Top Assembly Serial Number : FOC12296DTC
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-A-K9
Configuration register is 0xF
Thank you in advance,
John
jaichauh Wed, 10/01/2008 - 07:11
You have a LWAP. Thus, you need to convert it to Autonomous by using the following steps:
First download an autonomous IOS image from Cisco and then:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30, as AP gets an IP of 10.0.0.1 after reset by default.
Step 2 Make sure that the PC contains the access point image file (such as c1130-k9w7-tar.124-3g.JA1.tar for an 1130 series access point) in the TFTP server folder (Root folder) and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1130-k9w7-tar.default.
Step 5 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access point.
Step 8 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI or the CLI.
-Jai
