CME Accounting Code (Acct Softkey)
Oct 1st, 2008
I am using the Acct code on CME 4.3. Where can I report on these accounting codes? The call history in CME doesn't show them. Do I need to pump them to an outside server via syslog or Radius accounting somehow?
Can someone let me know and can you give me specific options as to software if that's what is required?
Overall Rating: 4 (1 ratings)
rob.huffman Wed, 10/01/2008 - 08:22
Hi Justin,
I have not used these but I thought that this might help get you started :)
Using Account Codes for Billing
Cisco Unified CME provides account code support into CDRs, which a RADIUS server or customer billing server then can use for the billing process. The Cisco Unified IP Phone 7960 and Cisco Unified IP Phone 7940 both support an account softkey so that users can enter an account code from an IP phone during the call ringing (alerting) or active (connected) states. This account code is also added to the Cisco-VOICE-DIAL-CONTROL-MIB SNMP MIB.
You can view the Account Code field in the show call active voice log, as shown in Example 14-41.
Router# show call active voice
Telephony call-legs: 2
SIP call-legs: 0
H.323 call-legs: 0
MGCP call-legs: 0
Total call-legs: 2
SetupTime=97147870 ms
AccountCode 1234
From the CME SRND Guide;
You might want to look into Cisco Partner "Stonevoice" that has a nice application;
Hope this helps!
jmbrady Wed, 10/01/2008 - 11:26
that's good info, thanks. Does anyone else have anything else to add. Maybe a quick way to print out the calls for reference?
