4.1 to 4.2 upgrade aborts on backup error
I'm upgrading some systems from ACS 4.1 to 4.2. The first three went fine. On the third the install aborts. I get an error message "Setup failed to export your old user database" and then "Setup could not backup your old configuration. Please check there is sufficient disk space and rerun setup."
1) over 20 GB of disk space free
2) I can do a database export from the 4.1 GUI ok.
any ideas?
Jagdeep Gambhir Wed, 10/01/2008 - 11:38
Please remove or relocate all the file from following location and then try ( these files are debug files, :
- Stop any anitvirus software that might be running.
- Ensure that if you are using CSMARS, and you are using pnlogagent, then that service is stopped, which can be done from services.msc.
- In the end, Also make sure that Drive on which ACS is installed or intallation folder or sub-folders are not shared.
Do rate helpful posts
Rebooting was not help. As there was not too much in the database, I tried doing an install without keeping the existing configuration. I then got Error at
V:\ismg_israel_acs\Acs\Crypto\init.cpp errors and eventually had to find and delete the old CryptoAPI container per your post
Fella, As we are getting error duri... by jgambhir - Nov 24, 2007, 7:22am PST
that worked!
