Mac, VM XP Pro, Cisco VPN, and Printing.
Answered Question
Oct 1st, 2008
I have an end user running a Mac with a VM XP Pro Machine that connects to our corperate VPN. This part works just fine. The problems come up when he tries to print to a local network printer. The job just sits until he disconnects from the VPN and then it prints just fine. Does anyone know what to do to fix this? I have little or no MAC knowledge.
Dan
Correct Answer by singhsaju about 8 years 8 months ago
That could be the reason why printing is not working. The printing traffic is actually going to vpn tunnel as split tunnel is not configured.
Overall Rating: 4 (1 ratings)
singhsaju Wed, 10/01/2008 - 09:40
  • Silver, 250 points or more
You can check if split-tunnel is enabled or not. If not then enable it .
Saju
Pls rate helpful posts
Correct Answer
singhsaju Wed, 10/01/2008 - 09:49
ddevecka Wed, 10/01/2008 - 10:01
That's what I figured but I hoped someone would have dealt with this in the past and have a work around other than split tunneling.
Dan
