VACL help
Oct 1st, 2008
I have Cisco 6500 SUP720 IOS 12.2(17d) with multiple vlans 5, 6, 7, 33 and 90.
Vlan 90 = 10.90.1.X network equipment
Vlan 33 = 10.200.1.6 my PC
Vlan 5, 6 and 7 = 10.5.1.X, 10.6.1.X and 10.7.1.X staff PCs
I want to be able to control access to vlan 90 so that only vlan 33 has access.
So I setup a ACL VACL and vlan access-map- like this:
ip access-list standard in-switches
permit 10.200.1.0 0.0.0.255
ip access-list standard allow-any
permit any
vlan access-map map90 10
match ip address in-switches
action forward
vlan access-map map90 20
match ip address allow-any
action drop
vlan filter map90 vlan-list 90
As soon as I apply the last command I lose connection to vlan 90 (can't ping it). What am I doing wrong?
Thanks in Advance:)
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 10/01/2008 - 09:04
  • Hall of Fame,
    Founding Member
Hello Joel,
I would try to use only the first block of the vacl
try the following
no vlan access-map map90 20
then apply again the vacl and tells if you see any difference
VACLs have an implicit deny at the end of the map; a packet is denied if it does not match any ACL entry, and at least one ACL is configured for the packet type.
the second aspect is that a standard ACL is used to match the source IP address only
I would use an extended ACL permitting traffic between the two subnets
no ip access-list standard allow-any
ip access-list extended in-switches
permit ip 10.200.1.0 0.0.0.255 10.90.1.0 0.0.0.255
permit ip 10.90.1.0 0.0.0.255 10.200.1.0 0.0.0.255
Hope to help
Giuseppe
burkmajo10 Thu, 10/02/2008 - 06:31
Giuseppe,
Thanks for the speedy response and your suggestion worked great.
Thanks again:)
