Trying to set up VPN Client with Hairpinning on ASA5510
Answered Question
Oct 1st, 2008
I am trying to set up our ASA5510 so users can connect to our work LAN and browse the Internet as well.
I've followed the Cisco guide, I connect and I'm given a 192.168.10.x address as needed but I can not connect to anything on our 10.0.0.0/24 work network nor surf the Internet.
Could someone please check my config and see what is wrong, there is also a L2L vpn on here to a 192.168.3.0 network but that works without issues
Many Thanks,
Chris
Correct Answer by singhsaju about 8 years 9 months ago
Hello Chris,
Add following access-list statement.
access-list INSIDE_nat0_outbound extended permit ip 10.0.0.0 255.255.255.0 192.168.10.0 255.255.255.0
And for hairpinning the internet traffic add following command:
same-security-traffic permit intra-interface
Check and post results.
Saju
pls rate helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
singhsaju Wed, 10/01/2008 - 09:47
  • Silver, 250 points or more
Hello Chris,
Saju
shaw.chris Wed, 10/01/2008 - 09:59
Thanks for your help, I already had "same-security-traffic permit intra-interface" but adding the access-list did the trick!
Thanks again
Chris
