IPCCX Upgrade - CAD Agent Re-install?
Oct 1st, 2008
Question: When you upgrade IPCCX from 4X to 5X, will agents need to re-install CAD agent/supervisor software or will their system automagically update CAD to the latest version as it did when upgrading within the 4X train?
Chad Stachowicz Tue, 10/07/2008 - 13:55
  • Silver, 250 points or more
CAD Has a feature for automatic updates, so as far as I know it will download the latest and greatest version on its own!
HTH,
Chad
Jonathan Schulenberg Tue, 10/07/2008 - 17:50
  • Cisco Designated VIP,
    2017 IP Telephony
Auto-upgrade is limited to maintenance release and ES updates. Minor or major version updates require an uninstall of the previous version and install of the new version.
andrew.higgins Tue, 10/07/2008 - 15:12
Per the CAD installation guide for UCCX 5.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_5_0/installation/for_cad/cad64ig.pdf
"To upgrade CAD from an earlier version, you must first remove the old version of CAD and then install CAD 6.4."
The CAD Feature Matrix is very helpful in determining which CAD version is included with each UCCX / UCCE release. It can be found at the following URL.
http://www.cisco.com/en/US/products/sw/custcosw/ps427/products_installation_and_configuration_guides_list.html
mikram Wed, 10/08/2008 - 01:07
  • Bronze, 100 points or more
After upgrade, try to run postinstall.exe file on CAD workstation.
