Oct 1st, 2008
I am installing a 2nd core switch and will be running hsrp between them. Currently one of my routing instances is for an IP VRF - it is called
ip vrf myers
rd 64576:1
For the 2nd switch would I have this as
ip vrf myers
rd 64576:2 ??
Or would it still be
ip vrf myers
rd 64576:1
, if all my routers in that VRF are HSRP'd?
Giuseppe Larosa Wed, 10/01/2008 - 11:32
Hello Denise,
I would suggest you to use different RDs because in this way you can have :
a) both PE's advertisements propagated by RR servers to all PE : faster convergence
b) if enabling in VRF eiBGP multipath and IGP cost to PE is the same a remote PE can even install both advertisements and you have flow based load-balancing for MPLS VPN traffic
note: What needs to be the same in a any-to-any VPN is the route-target that is used to decide what vpnv4 prefixes are to be imported in a VRF.
Hope to help
