edvalasek Thu, 10/02/2008 - 06:08
Okay, that is what I had been digging around in. So that helps me make sure I am on the right path...
I have noticed that when I try some of the reports it tells me that I only have data from May 2007 to January 2008.... Has something broken?
I am a newbie to the CCM and have been given the task to get very familiar with it.
Ed
Kenneth Mohammed Thu, 10/02/2008 - 07:35
  • Silver, 250 points or more
Nothing is broken. May 2007 is probably when the CDR flag was set to "true".
edvalasek Thu, 10/02/2008 - 07:39
How about the January date? When I select anything after January 2008, it says it only had data from May until January? That is what I am concerned about since it doesn't appear to have data from January up until today... Is data not being recorded somewhere? Settings to check?
Thanks again!
Ed
