Removing Unity 5 "mailbox nearly full" system message
Oct 1st, 2008
I'm new to the Cisco environment and have a question on how/where can I remove the system message on a subscriber box "mailbox is nearly full". I know there was a setting in an AD120 that allowed this however I cannot find the equivalent in the Unity v5. Any help would be great! thanks!
culittle Wed, 10/01/2008 - 12:29
  • Cisco Employee,
Go to the Tools Depot, Advanced setting tool, Conversation - Full Mailbox Check Feature, and Full Mailbox Check Prompt. Set the key value to 0.
Please rate this if it corrects your issue
julietrax Thu, 10/02/2008 - 06:47
The settings are either 0 or none (which is the equivalent of 0 according to the instructions) showing to NOT play, however it is still playing. Anywhere else I can look?
culittle Thu, 10/02/2008 - 07:12
  • Cisco Employee,
That is correct, a 0 value should stop the full mailbox check. Did you restart Unity?
julietrax Thu, 10/02/2008 - 07:15
has been restarted in the past week with those settings and restart is not an option during business hours. I'm at a loss.
