Telnet to Computer
Answered Question
Oct 1st, 2008
I am unable to telnet to a personal computer running Windows XP Home edition.
The connection is being denied. I am able to ping this computer. The firewall on the computer has been turned off.
Correct Answer by martinsp85 about 8 years 7 months ago
if you need to use telnet, perhaps try this one:
http://www.kpym.com/2/kpym/index.htm
Correct Answer by Jon Marshall about 8 years 7 months ago
Not particularly a Cisco question but :)
AFAIK windows XP Home edition does not run a telnet server so you won't be able to telnet to it.
XP has a telnet client so you can telnet FROM the machine but unless you install a telnet server onto the XP machines you won't be able to telnet to it.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 10/01/2008 - 12:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
