ios translation profile help
Answered Question
Oct 1st, 2008
Hi all, just wondering if someone could review my translation the goal is to make outbound caller ID for local as a 10 digit number and LD as a 11 digit number... thoughts? main number being 8015555555 example
voice translation-rule 1
rule 1 /^9/ /8015555555
voice translation-rule 2
rule 2/^91/ /18015555555
voice translation-profile outboundIDlocal
translate called 1
voice translation-profile outboundIDLD
translate called 2
dial-peer voice 1 pots
destination-pattern 9[2-9]......
port 0/0/0:23
translation-profile outgoing outboundIDlocal
dial-peer voice 2 pots
destination-pattern 91[2-9].........
port 0/0/0:23
translation-profile outgoing outboundIDLD
Correct Answer by basyadav about 8 years 3 months ago
Hi rywalker
I am not sure how many Digits you are using on IP Phones however if you have phone extensions like "5555" and "5556" and wants to change the Calling number only then the following should be the correct translation rules to achieve what you want:-
rule 1 /^555\(.\)/ /801555555\1/
rule 2 /^555\(.\)/ /1801555555\1/
For Single number "5555", following should work:-
rule 1 /^5555/ /8015555555/
rule 2 /^5555/ /18015555555/
translate calling 1
translate calling 2
port 0/0/0:23
port 0/0/0:23
-HTH
- Basant
Overall Rating: 5 (1 ratings)
MARTIN STREULE Tue, 10/07/2008 - 03:53
Try the IOS command "test voice translation-rule 2 "
This way you can review what's happening.
Cheers,
Martin
Correct Answer
basyadav Tue, 10/07/2008 - 04:54
Hi rywalker
translate calling 1
translate calling 2
port 0/0/0:23
port 0/0/0:23
-HTH
- Basant
