Microsoft OCS QOS Policies
Hey Folks,
I am working with a customer who is actively deploying a MS OCS solution using voice and video. From conversations with MS and others, it seems like MS uses SIP over TLS for signaling and then RTP for video and voice. They differentiate from Voice and Video codecs using different payload types.
Does anyone out there have any experience with matching on rtp payload type for this type of deployment. We would like to have the voice and video classfied in different class-maps so we can apply different levels of service to them.
smahbub Tue, 10/07/2008 - 13:20
Design and configuration guidance for Cisco advanced network services, including Cisco network-based server load balancing and firewall deployed with Microsoft Office Communications Server 2007 Enterprise Edition in a data center, the Cisco Application Control Engine (ACE) and Firewall Services Module (FWSM)are provided in the "Cisco Application Networking for Microsoft Office Communications Server Deployment Guide" present in the url given below:
saquib.mkhan Thu, 10/30/2008 - 16:51
Are you able to forward me the microsoft payloads ?
Secondly, are you narrowing down the udp ports required e.g.
Communicator side requires: 1024-65535
Server Edge: 49152-65535
Apreciate any documentation you have this regards.
RTA Narrow Band: RTP Payload Type 115
RTA Wide Band: RTP Payload Type 114
SIREN: RTP Payload Type 111
RTV: RTP Payload Type 121
We are in the process of narrowing down the port ranges. We had issues with matching on RTP payload. Specifically, we were unable to match the RTCP packets which were crucial to video surivability under load. MS says this was by design and recommended setting ports static on the endpoints via GP and then using ACLs to match based on those ports. We are in the process of that right now.
