Ace Sticky Configuration
Answered Question
Oct 1st, 2008
  • Bronze, 100 points or more
Hi Guys,
I'm trying to set up a sticky configuration on an ACE modeule in a 6500.
I've got the loadbalancing woking happily but need to ammend the config to add stickiness.
As far as I know the first command is someting on the lines of...
sticky http-cookie COOKIENAME STICKYGROUP
however when I put this in I get the following error.
Error: Sticy resource not available
I suspect that i'm missing something obvious.
Any assistance is greatly appreciated.
Steve
Correct Answer by Syed Iftekhar Ahmed about 8 years 6 months ago
By default all the resources are available to ACE contexts except sticky resource.
You need a resource class with sticky resource defined and this class applied to the context.
for example
resource-class GOLD
limit-resource sticky minimum 1 maximum equal-to-min
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 10/01/2008 - 17:10
  • Blue, 1500 points or more
for example
resource-class GOLD
Syed Iftekhar Ahmed
