Dial-Peer help
Oct 1st, 2008
Can someone help me with an example dial-peer configuration? I would like to see how to get a call coming in from a SIP VOIP network to get routed out a T1 trunk group. Thanks for the help in advance. Please let me know if I need to provide more info.
Overall Rating: 5 (2 ratings)
Marwan ALshawi Thu, 10/02/2008 - 04:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
ok
lets say from the calls coming from the sip dial 1234... to go thoguh ur T1
now we need to creat an incoming VOIP dial-peer and an OUTgoing POTS dial-peer
the voip take the call from sip VOIP link and the pots route it out through ur T1
dial-peer voice 9 voip
incoming called-number 1234...
codec g711
dial-peer voice 91 pots
destination-pattren 1234...
port [ur t1 port]
forward-digits all
prefix 1234
or what ever diggits change u wanna do
good luck
if helpful Rate
sdaniels44 Thu, 10/02/2008 - 06:23
Thank you for the reply,
I have taken your advice and I am still running into the same issue I had previously.
let me try to describe what is going on.
a sip call comes into my 3825 with the dnis 82589.
If I debug dial-peers I can see that it matches the incoming dial peer you had me enter. I can also see that it matches the outgoing dial-peer as well.
The issue is that sometimes the call makes it just fine, but about 60% of the time I get "I'm sorry there are no available lines to complete your call"
Let me paste the relevant entrys from my config:
card type t1 0 0
card type t1 0 1
card type t1 0 2
card type t1 0 3
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
isdn switch-type primary-dms100
voice-card 0
no dspfarm
trunk group 1
translation-profile incoming profile1
translation-profile outgoing profile1
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem passthrough nse codec g711ulaw
voice translation-rule 1
rule 1 // // type any national plan any isdn
voice translation-profile profile1
translate calling 1
translate called 1
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 1
description Sales Primary NFAS
controller T1 0/0/1
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 1
description Sales Backup NFAS
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d none nfas_int 2 nfas_group 1
description Sales NFAS
controller T1 0/1/1
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d none nfas_int 3 nfas_group 1
controller T1 0/2/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start dtmf dnis
cas-custom 0
trunk-group 1
description Concerto Tie #1
controller T1 0/2/1
framing esf
linecode b8zs
cas-custom 0
trunk-group 1
controller T1 0/3/0
framing esf
linecode b8zs
cas-custom 0
trunk-group 1
controller T1 0/3/1
framing esf
linecode b8zs
cas-custom 0
trunk-group 1
interface Serial0/0/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:23
voice-port 0/1/0:23
voice-port 0/2/0:0
shutdown
voice-port 0/3/0:0
voice-port 0/0/1:23
voice-port 0/1/1:23
voice-port 0/2/1:0
voice-port 0/3/1:0
dial-peer cor custom
name Local
name LD
name International
dial-peer voice 2 pots
description Outbound dial peer via TIE-LINE
preference 1
destination-pattern 8T
direct-inward-dial
dial-peer voice 101 voip
description IC Server #1
preference 3
service session
destination-pattern ....
session protocol sipv2
session target ipv4:10.2.1.13
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 102 voip
description IC Server #2
preference 2
service session
session target ipv4:10.2.1.12
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 pots
preference 1
destination-pattern 6T
direct-inward-dial
port 0/0/0:23
dial-peer voice 1 pots
description Default Incoming Dial Peer
incoming called-number .
direct-inward-dial
incoming called-number 82589
codec g711ulaw
trunkgroup 1 1
destination-pattern 82589
forward-digits all
prefix 2589
attached is output from a dialpeer debug
Marwan ALshawi Thu, 10/02/2008 - 06:34
if the called number come to the router as 82589 matched dial -peer 9 as incoming
the outgoing dial-peer has not port assigned to be send through
trunkgroup 1 1
forward-digits all
prefix 2589
u need to add a port
by the way the called number based on the above dialpeer will be send to the pstn as 2589 !
good luck
try it and let me know
sdaniels44 Thu, 10/02/2008 - 06:49
You are quick to respond! thanks!
Sorry, I should let you know that this trunk group is not going to the PSTN but rather a dialer system (Concerto) it expects the DNIS of 2589.
I didn't specify a port, but i did tell it to send it down trunkgroup 1, will this not work properly?
Sorry if I sound like a noob, but I am new to this.
Marwan ALshawi Thu, 10/02/2008 - 06:54
its ok
do u have the cloking between ur router and the system seted up corectly
when u do show isdn status do u have L1 L2 link state as connected or established
sdaniels44 Thu, 10/02/2008 - 06:58
Someone else mentioned that the clocking may be screwed up...
I am not sure how to check this, this trunk is not ISDN PRI.
