Warning message
Cisco ASA 5505 - locks up after about 2 days uptime
Oct 1st, 2008
I am using a ASA 5505 with two IPSec Tunnels & Remote users IPSec VPN's. I am finding that the unit locks up after about 2 days uptime. It remains visible locally so I can do an immediate system reload but there is no internet access, the tunnels gop down & the remote VPN users are unable to connect. After the system reload the unit is fine again until the next time. If I reload unit via ASDM it works for few minutes and locks again. But after power off/on it works for few days. Unit Version is 7.2(4).
suschoud Thu, 10/02/2008 - 06:54
  • Gold, 750 points or more
check interface speed and duplex settings.hard code it and avoid auto settings.
also,change the outside interface from e0/0 port to some other port.that would confirm if it's the e0/0 port which is bad.
Ssuhil
