Public IP's are used up, any way round this - port forwarding?
Oct 1st, 2008
We haev used up all our public IP's due to NATing them to static private IP's, before we spend the time and money on getting more which will mean a completely new scope, can I do anything else? Like use one IP for 2 server but differnt ports as some server use http and other ftp etc.
abinjola Thu, 10/02/2008 - 00:03
  • Cisco Employee,
exactly..you may do static port forwarding for inbound traffic
static (inside,outside) tcp x.x.x.x 25 y.y.y.y 25
static (inside,outside) tcp x.x.x.x 80 y.y.y.y 80
x.x.x.x--->public IP/Pix Outside Interface IP
y.y.y.y-->Private IP address
Do rate if it helps !
whiteford Thu, 10/02/2008 - 01:02
Should I be doing your method anyway or is the static method I'm doing normal practise or a bit of both.
I ask as I like to keep to best practices.
abinjola Thu, 10/02/2008 - 01:27
  • Cisco Employee,
Well again it depends, if you have enough public IPs you may go with 1-1 static, but if you only have very limited IP then static port forwarding is a better choice
Moreover static port forwarding is unidirectional, that is only from outside to inside, for outbound you need normal nat(inside) and global (outside) for that host
whiteford Thu, 10/02/2008 - 06:34
I guess I will have to add an rule on the Outside interface to allow this to work as I need an external public IP access to a private IP inside on a particular port?
abinjola Thu, 10/02/2008 - 08:18
  • Cisco Employee,
yes correct..you need ACLs besides the static port forwarding translation rule
whiteford Thu, 10/02/2008 - 10:32
I must of done something wrong, I added the port forward (PAT) from the outside interface to the private IP of the server on tcp/80 just like your useful example.
I then add a rule on the outside interface to allow any ip to the private IP on port 80, but I got get access from the Internet.
Have I missed something, do you have another example?
Many thanks!
abinjola Thu, 10/02/2008 - 10:38
  • Cisco Employee,
Use the command line and add the following
static (inside,outside) tcp interface 80 80
and in the outside access-list add
access-l permit tcp any host y.y.y.y eq 80
y.y.y.y-->outside interface IP
whiteford Thu, 10/02/2008 - 10:47
This is were I went wrong I think:
So because I have "bound" port 80 to my server the permit rule above knows how to get to the private IP?
Does this mean I can't use port 80 on another webserver?
abinjola Sat, 10/04/2008 - 10:21
  • Cisco Employee,
correct..if you are translating inbound traffic on outside interface for port 80 to a specific server, you cannot use overlap or duplicate statics to use port 80 again
