Interconnect CallManagers
Answered Question
Oct 2nd, 2008
Hi!
I would like to interconnect two callmanagers that belong to different companies although they have network connection between them. What exactly do I need to achieve that? Configure trunks and...
Ana
Correct Answer by MarkAJones about 8 years 9 months ago
Hi Ana,
Probably to much to detail here - if you look at help on your CM and search for "intercluster trunk" - this gives you all the information that you require..don't forget the QoS on the WAN link!!!
Hope this helps as a starter.
Mark.
Overall Rating: 5 (1 ratings)
Correct Answer
MarkAJones Thu, 10/02/2008 - 01:53
Hi Ana,
Mark.
