When show crypto isakmp sa ?
Oct 2nd, 2008
Dear All ,
I would like to ask you on ASA 5510 when i show crypto isakmp sa i saw responder and initiator. what are different and meaning? and next time i would like to know this issue how can i go to website for show this issue.....?
1 IKE Peer: 10.10.10.1
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
2 IKE Peer: 10.10.10.2
3 IKE Peer: 10.10.10.3
4 IKE Peer: 10.10.10.3
Type : L2L Role : responder
5 IKE Peer: 10.10.10.3
6 IKE Peer: 10.10.10.4
Note: both responder and initiator are working VPN.
Best Regards,
Join
ajagadee Thu, 10/02/2008 - 05:13
  • Cisco Employee,
I hope the below information helps.
In IPSec LAN-to-LAN connections, the security appliance can function as initiator or responder. In IPSec remote access connections, the security appliance functions only as responder. Initiators propose SAs; responders accept, reject, or make counter-proposals-all in accordance with configured security association (SA) parameters. To establish a connection, both entities must agree on the SAs.
In IPSec terminology, a peer is a remote-access client or another secure gateway.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/ike.html
Arul
** Please rate all helpful posts **
