10-02-2008 01:38 AM - edited 03-15-2019 01:41 PM
Hi folks,
We have several users who when they dial mobile numbers do not hear ringing tone but do get connected to called party.
Any ideas?
Rich
10-08-2008 08:21 AM
Ringback tones must come from the PSTN for trunk circuits in this situation. There are two dial-peer subcommands which can help. On the Cisco IOS router/gateway under the outgoing voice dial-peer # pots. You may try configuring the folloaing commands to resolve the issue.
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
10-13-2008 05:59 AM
Hi Jo,
This 'no ringback' issue only happens on calls to mobiles. I've had a look at the H.323 GW and there is no progress_ind anywhere!
Rich
10-21-2008 05:49 AM
I have the same issue for an internal person calling a number which has a song that plays instead of hearing ring-back. I added the following commands to the DP with no luck:
progress_ind setup enable 3
; there is no option for "progress_ind alert ". Am I out of luck? TIA - John
