VPN3000 Concentrator PSK recovery
Answered Question
Oct 2nd, 2008
Is there a way to view the group keys on a VPN3000 in clear text, either on the device or through 3rd party tools?
TIA,
Luke
Correct Answer by ajagadee about 8 years 7 months ago
Hello Luke,
I hope the below information helps.
Under Administration-->Access Rights -->Access Settings
Config File Encryption : check NONE , Then Apply.
The file can be viewed from following Tab
Administration ---> File Management
You will the config file and config backup file. There is very "view" button that you can click to view the file now.
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_41/administration/guide/access.html#wp1416303
** Snapshot from the Lab VPN3000 ***
[group 3]
name=Netpro
password=netpro
Arul
** Please rate all helpful posts **
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Thu, 10/02/2008 - 05:09
  • Cisco Employee,
Hello Luke,
[group 3]
name=Netpro
password=netpro
Arul
