Remote Access VPN - issue
Oct 2nd, 2008
HI all
im trying to set up a Remote Access VPN on pix 6.3 (where once connected you are assigned only 1 IP and that IP can only RDP to one server and although i connect to the the vpn ok, i cant RDP to that server. on the vpn client, the sent bytes are going up but the recvd bytes are 0.
on the remote server I have added a static route as follows:
route add mask interface of pix) its on same segment
below are the VPN configs:
access-list split-tunnel permit ip
ip local pool RA_VPN_SUPPORT mask
nat (inside) 0 access-list NONAT
crypto ipsec transform-set RA_VPN_SET esp-3des esp-sha-hmac
crypto dynamic-map DYN_MAP 4 set transform-set RA_VPN_SET
crypto map CRYPTO_VPN 99 ipsec-isakmp dynamic DYN_MAP
crypto map CRYPTO_VPN client configuration address initiate
crypto map CRYPTO_VPN client authentication RA_VPN_AAA
crypto map CRYPTO_VPN interface outside
isakmp enable outside
isakmp key ******** address netmask
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup RA_VPN_SUPPORT address-pool RA_VPN_SUPPORT
vpngroup RA_VPN_SUPPORT dns-server
vpngroup RA_VPN_SUPPORT default-domain
vpngroup RA_VPN_SUPPORT split-tunnel NONAT
vpngroup RA_VPN_SUPPORT idle-time 1800
vpngroup RA_VPN_SUPPORT password ********
lmather Thu, 10/02/2008 - 02:29
Do you have the access list "NONAT" specified in your config?
Do you have other working tunnels on the device?
Have you used the command "sysopt connection permit-ipsec" or allowed access to the LAN address on the outside access list of the PIX?
solpandor Thu, 10/02/2008 - 02:41
yes i have the access list NONAT configured
yes there is a site to site working ok
yes i have used the sysopt connection permit-ipsec command
lmather Thu, 10/02/2008 - 03:34
Does the server have an appropriate return route?
Can you ping the inside of the PIX from the VPN client if you specify "management-interface inside" ?
solpandor Thu, 10/02/2008 - 03:36
yes the server has a static route to via inside interface of pix as on same segment
no i cant.
