VPN connection issue between PIX
patel.nishit
VPN connection is flapping between two pix. This started after ISP rebooted the ADSL line.
It is happening every couple of minutes we lose connection for 1 or 2 minutes frequnntly.
Need help to resolve this issue.
ajagadee
Hello Nishit,
I hope the below URL is helpful in troubleshooting the issue.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
Arul
** Please rate all helpful posts **
This doe not help. The problem is with the VPN connection between PIX.
A user connected to A side Pix is using outlook, mapping drives, sharing files to connect to servers which is on the B side Pix.
Patel,
Have you done a bandwidth monitoring test to determine how much bandwidth your user needs?
If you run a continuous ping to 4.2.2.2 or yahoo.com do you get timeouts?
Post your configs... we cant help you just guessing what could be wrong... You can attach text files...
Give us an understanding of the connectivity...
The PIX connects directly to ADSL? If so, does it do vpdn for PPPOE authentication?
Joe
