Message "output packet too big" and then two interfaces goes down.
Oct 2nd, 2008
There is router that I saw a few times in the log the message "Output packet size of 1504 bytes too big", just after it two interfaces goes down. The IOS version is 12.2(25). Is it a hardware problem or it would be better to update the IOS version first?
Giuseppe Larosa Thu, 10/02/2008 - 22:59
  • Hall of Fame,
    Founding Member
Hello Luiz,
you have an interface with MTU 1500 and a bigger packet should be sent out of it.
Are you deploying MPLS ?
An ip packet of 1500 byte + 4 byte MPLS header makes a 1504 byte PDU that cannot be handled without increasing the MTU.
I've seen this message when deploying MPLS in a network.
depending on the IOS version and platform you could be able to increase the interface MTU or not
try
int fx/y
mtu 1508
I agree the ports shouldn't go down and so I would start to consider an IOS upgrade
Hope to help
Giuseppe
