smalkeric Wed, 10/08/2008 - 06:07
The first step in integrating MARS and Security Manager involves identifying those devices for which Security Manager is used to define policy rules. You must also ensure that devices are running a software versions supported by both MARS and Security Manager.
The following URL helps to integrate MARS and Security Manager:
http://www.cisco.com/en/US/products/ps6241/products_user_guide_chapter09186a00806512c7.html#wp1228772
According to my knowledge CSM 4.0 version is not available.
Security Manager supports two types of upgrades, namely, inline and backing up and restoring of data.
The following URL may help you:
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.2/installation/guide/upgrade.html#wp1080990
andrey.v.tyurin Fri, 10/10/2008 - 02:55
Hi!
You know, I am meaning that CSMgr has version 3.1 and MARS has version 4.1. I want to integrate MARS and CSM as You describe. I want to upgrade MARS and CSM to 3.2 and 4.2 or 4.3. Can I do this? Without any money. But I buy SMARTnet for this soft and appliance.
