Cisco 7206 VXR is rebooting frequently...
Oct 2nd, 2008
I have one Cisco 7206 VXR, which was running smoothly for the last 3 years. Last week it started rebooting...see the the attached carsh log file...any help in this regard would be highly appreciated...
Richard Burts Thu, 10/02/2008 - 06:58
Based on these lines in the crashinfo file I believe that your router has a hardware problem. If it is under a service contract I would suggest that you open a case with Cisco TAC.
%ERR-1-GT64120 (PCI-0): Fatal error, Memory parity error (external)
GT=0xB4000000, cause=0x0100E283, mask=0x0ED01F00, real_cause=0x00000200
bus_err_high=0x00000000, bus_err_low=0x00000000, addr_decode_err=0x00000470
%ERR-1-SERR: PCI bus system/parity error
%ERR-1-FATAL: Fatal error interrupt, No reloading
err_stat=0x81, err_enable=0xFF, mgmt_event=0x40
josephjob Thu, 10/02/2008 - 07:13
Hi Rick,
Thanks for your quick is not under service contract, I think it is memory related...any more update...
