FXS DID Card Config
Oct 2nd, 2008
If someone could confim that my configuration it would be much appriciated. We are cancelling our PRI at a location because it is no longer needed, and moving to a 4 line Analog DID trunk group with incoming abilities only. The significant digits coming from the carrier should be 4, and we are going to add a 7 to each of the numbers in order to sent the call to the employee's extension.
trunk group AnalogDID
voice translation-rule 3
rule 1 /^\(....\)/ /7\1/
voice translation-profile InboundDID
translate called 3
voice-port 2/0/0
trunk-group AnalogDID
signal did wink-start
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
dial-peer voice 150 pots
trunkgroup analogdid
description inbound Calling
translation-profile incoming InboundDID
preference 1
service default
incoming called-number 989757
direct-inward-dial
Will this work when I try to impement it? I am working with a 2821 and a VIC-4FXS/DID.
j.house Thu, 11/20/2008 - 11:54
Did you ever get inbound analog DID working? I have a similar scenario and am having issues.
pcameron Thu, 11/20/2008 - 17:30
  • Cisco Employee,
Don't put 'direct-inward-dial' on dial-peer 150. Because these are analogue ports this is not needed.
DID trunks are polarity sensitive as well (they rely on battery reversal to indicate wink, answer and disconnect), so you need to connect tip-tip/ring-ring correctly as well.
