Error when Sync'ing the startup configuration to the standby
Oct 2nd, 2008
  • Silver, 250 points or more
I need your help . I have 7600 seriers router which has redundant supervisor , on which if i do "write memory" i see following error messages in the Log , i have also checked nvram and found that startup config file size is 0 :
Oct 2 12:19:22.563 EDT: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router
Oct 2 12:19:22.567 EDT: %PFINIT-SP-1-CONFIG_SYNC_FAIL: Sync'ing the startup configuration to the standby Router FAILED
CATORMAR1R02
CATORMAR1R02#sh startup-config
Using 45560 out of 1964024 bytes
%Error opening nvram:/startup-config (Invalid Checksum)
CATORMAR1R02#cd nvram:
CATORMAR1R02#dir
Directory of nvram:/
1918 -rw- 0 <no date> startup-config
1919 ---- 0 <no date> private-config
1920 -rw- 0 <no date> underlying-config
1 ---- 4 <no date> rf_cold_starts
2 ---- 20 <no date> persistent-data
3 -rw- 0 <no date> ifIndex-table
1964024 bytes total (1960900 bytes free)
CATORMAR1R02#
Why is this happening and how can it be resolved? Thanks in advance.
