ASA5510-AIP10-K9 and Security Plus License
Answered Question
Oct 2nd, 2008
Am I mad? I tried to upgrade this base ASA device so I could make use of the Gigabit Ethernet which should work after the upgrade. I completed the license upgrade in the GUI and it was accepted see attached. I still have no GBe ports and the license had actually lowered the VPN count rather than increasing it. I have two identical devices which I need to run in A/A mode but am confused by the results. Please can anyone advise me?
Correct Answer by suschoud about 8 years 6 months ago
Please upgrade to 7.2.4.
e0/0 and e0/1 will start behaving as gig ports.
VPn count would be upto your satisfaction.
Do rate helpful posts.
Sushil
Overall Rating: 5 (2 ratings)
Correct Answer
suschoud Thu, 10/02/2008 - 11:40
  • Gold, 750 points or more
Sushil
timmatthews Fri, 10/03/2008 - 01:32
thanks v much Sushil, I guess I now have to upgrade to the 2 major release following 7.0(8)and then to 7.2..?
If the IOS works the same as routers, can you confirm this is the process, I only bought the ASA two days ago and Cisco won't support me because my SmartNET hasn't arrived yet!
suschoud Fri, 10/03/2008 - 06:16
You can directly upgrade to 7.2.4.
Here are the upgrade steps:
Download the asa software (asa724-k8.bin)from here:
http://www.cisco.com/cgi-bin/tablebuild.pl/asa
Download the TFTP server from here:
http://tftpd32.jounin.net/
-Unzip the TFTP server on a computer on the network
-copy the asa724-k8.bin file in the same extracted folder
-doubleclick on tftpd32.exe
-When you click on the 'show dir' button on the tftp server, the asa724-k8.bin file should be one of the listed files
-in the configuration terminal mode of the asa first ping the tftp server computer's ip address (you should be able to get ping responses)
-enter the command 'copy tftp flash'
-enter the ip address of the tftp server computer (press enter)and then enter asa724-k8.bin as the file name (press enter)
-it will ask you 'do you wish to proceed' - press 'y' for yes
-once you are back to the prompt issue the command
asa(config)# sh flash
Directory of flash:/
3 drw- 128 12:40:35 May 07 2006 asa724-k8.bin
7 -rw- 5539756 18:36:21 Jun 07 2006 asdm-521.bin
6 -rw- 1858 12:40:36 May 07 2006 downgrade.cfg
12 -rw- 8202240 18:29:04 Jun 07 2006 asa722-k8.bin
You would see asa724-k8.bin file in the list.
asa(config)# sh run boot
boot system flash:/asa802-k8.bin
This command tells us which file is in the boot system.
We need to change that to 803.bin.
That can be done by the command,
asa(config)#boot system flash:/asa724-k8.bin
'reload' to reboot the asa so that the new software version takes affect
-when the asa boots up again, issue 'show version' command to confirm if the new software is now running on the asa.
Sushil
timmatthews Fri, 10/03/2008 - 07:08
excellent, completely forgot about the appended bin file in boot, so pointed to 803, having reloaded 7.11/7.12 etc all the way up to 7.24 (time wasted, lol) anyway working fine - thanks again for your assistance on this one.
timmatthews Fri, 10/03/2008 - 06:43
thanks Sushil I will try this process now and let you know how it goes.
