10-02-2008 09:25 AM - edited 03-13-2019 05:42 PM
I was curious, is it possible to run IPCCx and CCCx on the same server...if so, is it recommended?
Solved! Go to Solution.
10-04-2008 12:00 PM
You can have UCCX 3.x & 4.x co-resident with CCM 3.x & 4.x up to UCCX version 4.1(1).
After this (UCCX v4.5) you have to install the software on a seperate server to the CallManager, mostly due to the OS incompatability.
I've attached a useful compatability matrix for you to look at which shows specific information on which versions of CRS work with which version of CallManager (it has a load of other useful info as well..;0)..):
Hope this helps.
Please rate useful posts....
10-03-2008 12:26 PM
With CCM4.x, yes.
After CCM 5.x, no.
10-04-2008 12:00 PM
Hope this helps.
10-06-2008 05:13 AM
Thanks! that was quite helpful.
