DFM 2.0.11 Notification Groups
Answered Question
Oct 2nd, 2008
I have dfm 2.0.11 installed on Windows2000 server. When I try to modify/edit my existing notification group, it does not do anything. However, I am able to add a new notification group. Please advise. Thanks in advance.
Pete
Correct Answer by Joe Clarke about 8 years 9 months ago
JRE has nothing to do with it. DFM is all non-Java on the client side. It is more likely an issue of needing to clear your browser cache.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 10/02/2008 - 10:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What are you changing in your existing group? What errors/pop-ups do you get?
power1pete Thu, 10/02/2008 - 11:10
I just realize the problem only happened on one workstation. When I try to open the existing group in the localhost of the server and a different workstation, I was okay.
Let me try to un-install and re-install the JRE for that workstation. I will let you know the result. Thanks Joe.
Correct Answer
Joe Clarke Thu, 10/02/2008 - 11:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
power1pete Thu, 10/02/2008 - 11:59
Okay, empty out the browser cache did it. Thank you very much for your help Joe!
