10-02-2008 11:17 AM - edited 03-11-2019 06:52 AM
We are currently running a Pix 515E 6.3(5), no failover mode. I am getting alot of drops on the outside interface on SMTP port. The error is 106015 Deny TCP (no connection) from IP_addr/port to IP_addr/port flags. I have researched the error and it appears that this is a malformed smtp packet that is getting discarded. Is this usual behaviour or is this something I should be looking at ?
I am dropping this traffic from a wide range of public IP's.
Cheers
Dave
10-02-2008 11:28 AM
Do you have fixup protocol smtp 25 enabled? If so, try disabling it as it has been known to cause a lot of trouble. >>
no fixup protocol smtp 25
10-02-2008 11:30 AM
I do have the fixup protocol enabled.
Can i just enter the no fixup command without affecting the mail flow, or is this something that should be done afterhours ?
Cheers
Dave
10-02-2008 12:27 PM
you can run this command during production hours.It just puts a lot of constraints on what smtp commands can pass through f/w.Removing these constraints ( fixup ) would not affect the mail flow.
Sushil
