4510r-e arp
Oct 2nd, 2008
I would like to know why the 4510r-e installed on a customer only show few mac-ip. The switch has more than 300 ports installed.
I want do a show mac address-table and show arp to match the macs and know which ip is connected on each port.
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 10/02/2008 - 14:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Is the 4510 acting as a layer 3 or layer 2 device.
If layer 2 then you would expect to see a large mac-address table with 300 active ports but a small arp table. The majority of arp entries will be on the layer 3 devices responsible for routing the L2 vlans on the 4500.
If layer 3 then you would expect to see both a large mac-address and large arp table.
Jon
Rafael Jimenez Thu, 10/02/2008 - 14:09
How I know it the 4510 actig?.
I have several SVI with ip routing enabled.
Jon Marshall Thu, 10/02/2008 - 14:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sounds like the 4500 is acting as a Layer 3 device then.
Are the 300 devices
i) active - because if they are not then their entries will time out of the arp and mac-address tables.
ii) within the vlans that you have SVI's for on the 4500.
Jon
Rafael Jimenez Thu, 10/02/2008 - 14:17
Acording with your firs answer , i believe the problem is that in this moment all PCs and other devices are using another device (a router) as default gateway.
I had to swap the ip address of the router and the svi in that vlan.
Despite I have several vlan created all servers, pcs, printers, etc.... are the same vlan,Im working on that becasue I has to reconfig several devices, routes, firewalls, etc before move pcs to others vlans.
Thanks.
Jon Marshall Thu, 10/02/2008 - 14:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
"i believe the problem is that in this moment all PCs and other devices are using another device (a router) as default gateway."
that would indeed explain a small arp table on the 4500.
Good luck with the move.
Jon
