Correct Answer
Chris Deren Thu, 10/02/2008 - 16:39
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Yes, this is available in CM 4.2/4.3 as well as CM 6.X/7.X
HTH,
Chris
metalium2007 Fri, 10/03/2008 - 05:40
  • Bronze, 100 points or more
Cderen,
I dont doubt of your answer and indeed i've tried this function in some versions of ccm and its only possible from 4.2.
Do you have any document that shows the inclusion of the functionality from 4.2?
thanks,
Met.
Chris Deren Fri, 10/03/2008 - 05:45
  • Hall of Fame,
From CM 4.2.1 release notes
Cisco recommends that an assistant use the Cisco IPMA-on-phone features only if that assistant supports no more than five people.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/4_2/cucm-rel_notes-421.html#wp2437923
look through CM Admin/Feature and System guides for more info.
Chris
metalium2007 Fri, 10/03/2008 - 05:50
Thank you very much cderen.
5 points for the fast and objective response.
Met.
gmcleveney_2 Sat, 10/04/2008 - 07:59
Chris,
Thanks for your answer. Is this fearure in CCM5.X too?
Chris Deren Sat, 10/04/2008 - 08:44
  • Hall of Fame,
No, CM 5.X does not have any of the new CM 4.2 features.
Chris
metalium2007 Sun, 10/05/2008 - 02:10
Sorry but controling IPMA from the assistant phone without the pc console is possible in 5.x. Been there, done that.
Hope this helps!
Met
gpsriramdc Mon, 01/25/2010 - 05:16
Hi !
I tried IPMA service in the assistant phone [ CUPC] it's won't working.
Assistant Phones subscribed the IPMA service.
whether IPMA-on-phone services only for Manager,or it's depends on device model.
CUCM version 7.1.2  CIPC version 2.1.2
