ASA 5520 Interface Frequently Reset.
Oct 2nd, 2008
The interface G0/1 of our ASA5520 has a large number of interface resets when issue show interface command. This number increase every several minutes. Other interfaces are ok.
I am very sure there is no cable and patching problems, because I have test cable with another box.
When the interface reset, I can not ping it. After several missing pings, it recovers to normal.
Please anybody knows it is hardware or software problem?
My software version: 7.2(2)33.
Many thanks.
Show inte g0/1
Interface GigabitEthernet0/1 "HBOS_PROD", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Description: HBOST Production
MAC address 001b.0c38.cf0b, MTU 1500
IP address 10.50.41.226, subnet mask 255.255.255.224
19555520 packets input, 1885248296 bytes, 0 no buffer
Received 34705 broadcasts, 0 runts, 0 giants
0 input errors, 206 CRC, 0 frame, 0 overrun, 206 ignored, 0 abort
0 L2 decode drops
32664879 packets output, 35252998804 bytes, 0 underruns
0 output errors, 0 collisions, 11334 interface resets
0 late collisions, 0 deferred
0 input reset drops, 19 output reset drops
input queue (curr/max packets): hardware (0/29) software (0/0)
output queue (curr/max packets): hardware (0/7) software (0/0)
guo6688 Thu, 10/02/2008 - 22:54
This is solved. Thank you. It is patch port's problem.
Anyway, thank you for reveiew.
