Router 7606 policy-map
Oct 2nd, 2008
Could you help me, please.
User terminate pppoe session and must get service-policy input and output from RADIUS server. And router get it, but can't set output policy in Virtual-Access interface.
Router 7606-s
In log:
%SW_MGR-3-CM_ERROR_FEATURE_CLASS: Connection Manager Feature Error: Class SSS: (QoS) - install error, ignore.
-Traceback= 85501E8 85508F4 94ABAFC 94BE36C AEEC180 AEEC210 94BE610 94BE810 94BECBC 94AACF4 94AAE4C 94A5950 94A5D74 A6A07B0 A696310
Problem with this policy:
access-list 101 permit ip any any time-range TST
class-map match-all TST
match access-group 101
policy-map 64K
class TST
police cir 131000 bc 131072 be 131072
conform-action transmit
exceed-action drop
class class-default
police cir 65500 bc 65536 be 65536
exceed-action drop
but with this polisy have not problem:
policy-map 100K
class class-default
police cir 102000 bc 102400 be 102400
exceed-action drop
policy-map 64K install only as input, but doesn't work properly.
All traffic match to class TST, even through time-range doesn't match.
Both policy-maps work properly on 7204 router.
Giuseppe Larosa Fri, 10/03/2008 - 04:24
Hello Elena,
I think you are facing a functional limitation of multilayer switch C7606:
there are different TCAM tables that are used for different purposes including an ACL TCAM.
A time based ACL is something different then normal ACL I don't know if they are supported in ACL TCAM table.
The TCAM entries should be modified with action permit or drop at the time range boundaries.
Verify also the clock on the C7606 because it needs to be in sync with an NTP server to be accurate.
the C7204 is a software based router and so its implementation is different: less efficient but with more functionalities.
probably the time-range is ignored.
Or at least it is a problem with the current release. May you provide more info like type of supervisor and IOS image name ?
Hope to help
Giuseppe
elena.rus Fri, 10/03/2008 - 05:41
Thanks for your help, Giuseppe!
With NTP all is ok.
Information from "sh ver" :
Cisco CISCO7606-S (M8500) processor (revision 1.0) with 851968K/65536K bytes of memory.
Processor board ID FOX1220H7C4
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC2, RELEASE SOFTWARE (fc2)
if it ignored in policy-map, does it also must ignored in Access-Group in interface?
Giuseppe Larosa Fri, 10/03/2008 - 05:53
Hello Elena,
Here we enter the field of implementation details.
It is possible that an access-list applied directly to interface can use the time range because it is present in command reference, but at the same time an ACL used within a qos policy-map cannot use time-range because the code does not retain this info and doesn't pass it to another routine that has to build the TCAM entry later used for the policy map.
I would suggest you to open a TAC service request for this issue: customers can propose new features/improvements also using this channel
Hope to help
Giuseppe
elena.rus Mon, 10/06/2008 - 14:58
Hello, Giuseppe
With error we have arrived at a solution
Now we use hQoS instead of two class with "police" in the same policy-map.
There is just one problem - time-range is real ignored.
We open a TAC service request for this issue.
