satish_zanjurne Fri, 10/03/2008 - 00:21
  • Silver, 250 points or more
1.Your 8 fiber port requirement can be fulfilled only by using Chassis switch like 4500 or 6500, where you can have one blade/module of ethernet ports & one module/blade of GBIC/SFP ports.
2.But other option is Using 2 catalyst 3750 , switches one all UTP/RJ-45 & other all fiber ports , stack both switches using stack cable.
Cisco Catalyst 3750 - 24TS
24 Ethernet 10/100 ports and 2 small form-factor pluggable (SFP) ports
Cisco Catalyst 3750G-12S
12 SFP ports
3.None of one U the switch is having 8 ports as fiber.
HTH..rate if helpful..
jeffersoncbriones Fri, 10/03/2008 - 00:38
Hi Satish,
Is there any switch with 8 GBIC modules? another thing if i use SFP, i need to have a SC-LC for it, and it should also be multimode right ?
Thanks.
satish_zanjurne Fri, 10/03/2008 - 01:37
1.Below is the switch with 10 GBIC
Catalyst 3550-12G Switch-10 GBIC-based Gigabit Ethernet ports and two 10/100/1000BASE-T ports; 1.5 RU
2.Hi , it depends on what the device is taking
Fiber Cables will be available in both types
SC-LC as well as LC-LC , both single mode & multimode depends on the distance between end devices.
