unable to save config on C3750
Oct 2nd, 2008
I am unable to save the new configurations, when ever i try to wri new config in my switch it gives an error "startup-config file open failed (not enough space)
i have recently upgraded the IOS on this switch,
if i try to add a VLAN or configure SNMP on the switch it reboots and all old configuration will be lost,
below are the switch details,
Switch#sh flash
Directory of flash:/
2 -rwx 10761792 Mar 1 1993 00:18:14 +00:00 c3750-advipservicesk9-mz.1
22-44.SE2.bin
3 drwx 64 Mar 13 1993 23:53:03 +00:00 crashinfo_ext
5 drwx 64 Mar 1 1993 00:00:03 +00:00 crashinfo
8 -rwx 856 Mar 1 1993 01:58:18 +00:00 vlan.dat
15998976 bytes total (4964864 bytes free)
Switch#
Switch#sh boot
BOOT path-list : flash1:c3750-ipservices-mz.122-25.SEB4/c3750-ipservices-mz
.122-25.SEB4.bin
Config file : flash:
Private Config file : flash:/private-config.text
Enable Break : yes
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 15:42 by antonino
Image text-base: 0x00003000, data-base: 0x01840000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
Switch uptime is 4 days, 2 hours, 28 minutes
System image file is "flash:/c3750-advipservicesk9-mz.122-44.SE2.bin"
Let me know the reason and solution for the same,
Thanks & regards,
Kiran
satish_zanjurne Fri, 10/03/2008 - 01:56
This looks like the bug in the IOS
Try downgrading to the old IOS & then see.
If it works with old IOS ,definitely it is IOS bug,
Then try to use stable version of ADVIPSERVICEK9
HTH..rate if helpful..
glen.grant Fri, 10/03/2008 - 03:43
Do a dir flash and see how much space you have left out of the total, if need be delete your old image out of flash or delete the new image and reload the old one and see what happens.
kirankumarhm Fri, 10/03/2008 - 22:38
Thanks for your reply,
I am unable to execute that command, it says the same error,
