Extension mobility with BLF
Oct 3rd, 2008
Hi guys,
I have BLF running on phones by simply configuring the subscribe calling search space. My problem is with the extesion mobility users. I configured the subscribe calling search on the end user under the Extension Moblity panel but nada.... both the operator with BLF speed dials and the coporate user list aren't showing any BLF status (as if they were unregistered)
Any suggestions ?
nowcommsupport Fri, 10/03/2008 - 04:05
Hi there,
For Corporate Directory to work there is an enterprise parameter near the top for "BLF for Call Lists".
After you've enabled this you should be good to go, providing you have set up the partitions and call-search-spaces correctly.
Hope this helps!
