CUBAC
Oct 3rd, 2008
Hi, I have installed CUBAC on a Win 2003 server. The installation went fine with no error. However when I try to access the web admin page (http://ip address/WebAdmin/login.aspx), I get the error message: HTTP 404 - The page cannot be found. Has anyone come across this problem?
Chandrasen
ebreniz Thu, 10/09/2008 - 08:24
  • Silver, 250 points or more
On reinstalling Windows 2003 server and service packs. The problem will resolve. Try the bug id CSCso12130.
Fasalullatp Thu, 01/08/2009 - 02:54
Am getting the same problem in my workplace also.If you solved that please share the details.Thanks in advance
martinwittmann Mon, 02/23/2009 - 07:49
reinstall/Change the .Net Framework over Add or Remove Programs in the Control Panel
hbarrera2 Tue, 05/05/2009 - 07:28
martinwittmann,
I have the exact same issue. I am showing the following in my add/remove programs:
- .NET Framework 2.0 SP2
- .NET Framework 3.0 SP2
- .NET Framework 3.5 SP1
Which one should I remove?
Thanks.
Fasalullatp Tue, 05/05/2009 - 19:37
Where did you installed CUBAS.Here you mentioned CUBAC.If it is CUBAS,please check the access from another system.
hbarrera2 Tue, 05/05/2009 - 19:49
I actually resolved my issue, I removed all of the .NET Frameworks listed in my previous post, rebooted the server uninstalled CUBACS rebooted again. Reinstalled it and now the web page access is working.
I did notice the Server app loaded its own package of .NET Framework 2.0 SP1, before it continued with the install.
HTH!
