easy vpn remote feature
Oct 3rd, 2008
I have a 2611 router with ios:c2600-i-mz.120-10,DRAM/FLASH is 26624K/6144K
and the compact flash is 4966520.
Could it support Easy vpn remote feature?If not which IOS/DRAM/FLASH could be appropriate ?
satish_zanjurne Fri, 10/03/2008 - 05:24
This feature is not supported on Cisco 2611.
It is supported on 1700 , 1800 , 2800 series routers.
HTH..rate if helpful..
